Lexus vs M931 bobtailed, got rear ended
Csm Davis
381
Hattiesburg, Mississippi
Slowing from highway speed to turn on dirt road, and got tagged pretty hard.
View attachment 698707View attachment 698708View attachment 698709
So now we have a broke truck. Will start making insurance calls in the morning after the adrenaline wears off.
Hey 155mm glad everyone is going to be okay, except for your truck it is totalled, don't take my word for it have a insurance adjuster go through it and write it up and also a body shop with a good frame machine to measure if the frame is still square bet it's not. Even if the frame is still square, the repairs to the motor transmission and transfer case, that all have to come out will be more than what the truck is worth. Let the insurance company total the truck, buy it back for scrap price and buy new truck to put all your good stuff on, like those nice tires. I know you may be attached to the truck but I don't think it will be worth rebuilding even if the frame is still square. It can have lots more hidden damage.
Sent from my SM-G930V using Tapatalk
TexAndy
15
Bee County, Texas
Yeah, it's all that stuff you can't see that might be damaged that I would be worried about. Like DH said, maybe the insurance company will let you buy it back as a parts truck.
Rescue101
Bridgton Maine
It was GONE the minute you found the transfer case problem.........with the broken bellhousing there is NO doubt..........If they can afford a Lexus,they SHOULD be able to buy you a replacement GREEN machine
155mm
Chief and Indian
387
Guymon, OK
Spend 4 hours digging thru tm's and MAC charts building just a time estimate for repairs. Insurance adjuster was like... 'uh, um, I, uh... I dont know where to start to look.'
Estimated time for just the visible damage according to the MAC chart including initial and follow up tasks is 82 hours. Thats based on army mechanics in shops with electric overhead lifts, proper special tools, new parts. So I guess it will take at least another 20 hours with mechanics unfamiliar with green iron, fire wrench time, and mechanical lift or fork lift lifting.
So even in a very cheap shop, shop rates are at least $100/hr, so far that means, on the conservative side, $10,000 in labor alone. So it looks to me to be totalled because I can get a comparable replacement for 15+, plus freight.
155mm
Chief and Indian
387
Guymon, OK
After having another green iron owner come by and look with me, well the frame is out of square.
thats the cab mount on the right side, see how the bolt is leaned forward.
Exhaust bracket on frame behind cab, space between bracket and frame rail, paint is 'cracked'
This crossmember took alot of force, its 'buckled' where the paint is missing. I know there are supposed to be some divits at those spots, these have bent the metal enough to pop the paint off.
98G
Former SSG
4,190
Equipment and toys, no matter how nice or how rare, can be replaced.
Thankfully there's no mention of severe injury or death.
Let the insurance company pay out at current market value, that's what they're for. When push comes to shove, that's how this will play out. (They're either going to pay $40K in repair costs or $20K to replace) Then go shopping for an equivalent or better truck.
There's some stress in the meantime, but this one is very straightforward. There's no question how this will play out. Thankfully the truck isn't your primary source of income, so you're under no pressure to settle until the resolution is satisfactory.
155mm
Chief and Indian
387
Guymon, OK
I already have one picked out, and already engineering ways to put more lights on the back of the cab so there isnt a visibility question even though I know there isnt a visibility issue with the factory lighting.
Luckily there is no rush to get this resolved either, gives time to do it right, not do it in a hurry.
98G
Former SSG
4,190
Some thoughts on additional visibility -
Mud flaps with copious amounts of conspicuity tape - removable, with no permanent alteration to the truck.
Hang a set of wrecker tow lights on the back. They plug right in, and again make no permanent alteration to the truck. And then you always have tow lights available for anything you need to tow.
(I realize this is obvious for many people reading it. I add it for benefit of those who may not have considered it.)
155mm
Chief and Indian
387
Guymon, OK
Mudflap brackets like this but removable for towing short necked trailers.
Towlights high mounted on spare tire lifting tree
155mm
Chief and Indian
387
Guymon, OK
And then there were none.
I did send her off with her ribbons on, I figured she deserved that.
lindsey97
wynnewood, oklahoma
I would suggest installing some strobe lights and a very sturdy set of HAY FORKS on the back of the next truck. Hate to see the truck destroyed, but very thankful your family is ok. The truck absorbed a lot of energy.
NDT
6,183
Camp Wood/LC, TX
I would have fixed the truck and painted a rising sun flag on the cowl. Americans had to fix a lot of military equipment after similar jap kamakazi attacks.
155mm
Chief and Indian
387
Guymon, OK
Insurance bought it, they wanted 1/5th of the check if i wanted to buy it back. I told them to come get it, it wasnt worth 1:5th of the payment
