What is the name of panel of rotary switches that direct air to the cab, suspension?
Reworked LMTV
1,174
TN
I'm having issues with the panel of rotary switches that direct air to the cab, suspension mounted on the passenger side of the truck. I need to search for info. Anyone know the official name of this thing?
simp5782
Feo, Fuerte y Formal
9,385
Mason, TN
This thing?
hydraulic control valve body. NSN 4730-01-457-8479 Manifold Hydraulic System Access.
simp5782
9,385
Mason, TN
Yes, thank you. Can you rebuild these? Mine seems to be leaking air out inappropriately.
Im sure you can. You can take it your local parker store abd they can send it to their rebuild facility. Not sure of the cost. Their facility in blytheville, ar does my walking floor hydraulic cylinder rebuilds.
Or any hydraulic cylinder repair place can rebuild it i am sure. Suprman has units gor sale though if the cost of rebuild is high
Sent from my SM-G935P using Tapatalk
tennmogger
543
Greenback, TN
If the problem is air leaking from the hydraulic control valve body that might be good news. I think there is only one valve on the hydraulic control that has air and that's the one you push and hold to activate the air to hydraulic pump up behind the hydraulic control. All the other circuits are hydraulic. If the air leaks out before the pump gets air then there will be no hydraulic power.
What is the nature of your failure? Nothing works?
Suprman
696
Stratford/Connecticut
There are 2 air circuits. One for the cab airbags and one when you press the hydraulic actuation valve button it send air to the air hyd pump. This control has a check valve behind it with o rings. It will unscrew and you can take a look at it. There are 2 different styles. I have the replacement valve and check that goes in behind it if yours is just bad.
tennmogger
543
Greenback, TN
Oh, forgot that one! Thanks Will. I assumed the OP was concerned with cab lift, suspension (kneeling circuit) etc. More info needed.
firefinder
10
Macon,MO
I had a leak in the switch manifold. Turned out to be the push button switch for the cab air bags (or air springs as listed in the Operator's Manual). All of the o-rings were available locally. Once the o-rings were replaced, everything worked fine. Photo of the switch I rebuilt:
Here is a related prior thread with rebuild kit info and photos of other components:
https://www.steelsoldiers.com/showthread.php?155350-Coolant-Took-A-Vacation/page4
Reworked LMTV
1,174
TN
Thanks Firefinder! I love rebuilding things....well...most things ; )
Reworked LMTV
1,174
TN
Yes, nothing works. Air now rushes out from the lower rear of the manifold if right lower control is not pushed in and turned. Cab is stuck slightly open (probably air from hydraulic pump rebuild? ). I can hear the pump trying to work with minimal air, then a valve kicks in and shuts down the air to the pump. Manual pump now will not working either.
I think there are 2 issues with my air / hydraulic system.
Suprman
696
Air coming out the back of the manifold is usually the check valve behind the control knob. Could just be the o rings on it though. If the air is escaping and not making it to the air hyd pump then you wont get much hyd pressure. If the manual pump dosnt work then you are probably low on fluid or have air pockets in the system.
coachgeo
3,463
North of Cincy OH
Yes, nothing works. Air now rushes out from the lower rear of the manifold if right lower control is not pushed in and turned. Cab is stuck slightly open (probably air from hydraulic pump rebuild? ). I can hear the pump trying to work with minimal air, then a valve kicks in and shuts down the air to the pump. Manual pump now will not working either. ..I think there are 2 issues with my air / hydraulic system.
did this all start after rebuilding manual cab lift pump? And these issues where not there before? If so that might change things when considering diagnosis
Reworked LMTV
1,174
TN
Well, it first started with the blowing of hydraulic oil out of the air / hydraulic pump. I had noticed that this pump was getting slower and struggled to lift the cab. I checked the manual pump, and at the time of the air / hydraulic rebuild, it worked fine. Are the cab hydraulics PowerPacker like the air suspension?
Suprman
696
Ok so you are low on fluid because it all blew out the breather. Put fluid in the hyd pump reservoir and work the hand pump to get the air out.
Reworked LMTV
1,174
TN
I already refilled it and the manual pump will not move it. I assume I just crack a line to get the air out?
aleigh
52
Phoenix, AZ & Seattle, WA
When some of my valves went bad due to corrosion I had the same symptoms OP describes. It was quasi sporadic. The pump was working against a check valve or whatever that wouldn't open - it was actually on the fluid release side (past the cylinder) in my case. To get the cab down I had to crack a line and let it bleed out (since it couldn't return to the reservoir). When I took the entire manifold apart it had corrosion everywhere so if he's having these problems my advice is pull the whole thing and pull all the valves or you might just be back at it in another six months when the next one goes.
The stock fluid has no corrosion protective properties - replace with another hydro fluid that does (what I did anyways).
https://www.flickr.com/photos/adventioneering/albums/72157669897327435
Reworked LMTV
1,174
TN
Thank you for your input. You are an asset to this forum : )
Reworked LMTV
1,174
TN
Good photos at flicker. Looks like you did fuel lines too. I need to do that.
There was all sorts of gunk in the hydraulic fluid tank. I assume it is elsewhere. My symptoms sound like the ones you had. The pump seems to be fighting a valve. I'd like to flush the who system. Hard to understand a Mil truck would have no corrosion control in the hydro fluid.
