Air source
Russ Knight
1,054
Perry, FL
Where would be the best place to tap into the air system for an auxiliary air source to run tools, inflate tires, etc?
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
A Gladhand on the right rear and drivers front. Found at your local truck parts place. You Just need 3/8" air line. About 15' of it. a Glandhand connector and your quick connect air fittings on the other end.
I don't recommend using air tools off the truck. It isn't very powerful and can take forever since it is only 1 small tank that the emergency lines feed off of.. You need to invest in the Dewalt 20v XR High Torque Brushless 1/2" drive impact or a Milwaukee Fuel Series 18v impact. They are bad guns. They can take off lugnuts with ease that a 1 inch air gun puts on.
dmetalmiki
2,027
London England
I use the rear glad hand (the red emergency one) and also have a 1/2 bsp connector from the bottom air tank. (which also powers the air mast.) Both work fine, but the 'monster' 3/4 drive air impact carried for wheel changes runs (OK) from the rear gladhand.
Don't use the front gladhand as it is for input towing only. No air comes from it.
I also use the air supply from the connector (with a tap) under the dash for some items.
Jericho
69
Landaff NH
I agree Mickey, I run a Full stud air nailer off mine at remote build sites all the time. Works for those small air tools and great for airing up tires and air matresses at the campsite !
