Jayco36REQS
- 2
- 16
- Orlando/FL
I have a M923A1 that is a 2010 rebuild. It started having fuel problems awhile ago where it would chug and spit and no power until it got warmed up. Once warmed up it ran fine. I don't drive the truck much... But this went on for several months. Then I went out to move it, and it it started, but didn't run long enough to warm up and it died.. and wouldn't start again. It will start on starter fluid, but won't stay running. So far I've:
- Drained the fuel tank and cleaned it, added fresh diesel.
- New Fuel filter, cleaned the housing, w/ new O-rings
- New PT pump filter screen
- Primed the system
- Checked that fuel is coming out of the fuel line at the motor while cranking
I saw one post saying that they had a stuck return line check valve... and my engine doesn't have one? I've traced the return line from the motor to the tank, and there isn't a check valve, unless it's inside the tank??
Can anyone offer any other ideas where to look now? HELP!!!! lol
- Primed the system
