- 1,700
- 391
- 83
- Leavenworth, KS
Just got around to servicing a MEP-531 I picked up a little while ago; changed fluids and filters and fired it up. As usual it took some fuel bleeding and a bit of cranking to get it to run. Once it fired I starting getting quite a bit of popping and some “backfires” thru the exhaust. Any experience with this or thoughts on easy fixes before I tear into the head to check valves, check timing, and whatever else I can think of?
