- 1,175
- 387
- 83
- Guymon, OK
We will be east bound from Missoula tomorrow noon to i-25 to i-70, if you need help pm me
I'm a 30 year hd diesel mechanic with both military and commercial experience, when I read stuff like this it makes me feel so good when some one shows me a piece of paper than says look at this I smarter than you. First over fill oil by 5 gallons stupid, secondly another tech drains out 4 gallons, and doesn't check for fuel dilution, and 3rd sends you on your way saying every thing is good WTF, the guy has a crystal ball, or he doesn't know about what happens to the oil when the crank and rods start rotating it the oil OMG, Must not be a question asked on his fancy test. I'm not knocking the ASE credentials I likely would have them too if it didn't have to spend so much money to fly to a city to get them, But it takes time more than a test for someone to be a master mechanic these big outfits need to learn this and stop hiding behind certificate's. Sorry about the rant but it seems the big outfits that want your business so much don't have a compensation package in place to attract senior mechanics that really know what they are doing.Thanks for the help everyone!
Looks like the tread is going to be able to get us home.. That's not the issue now...
We are stuck in Spokane. Travel America in Missoula overfill are oil on the oil change by 4 gallons and didn't check dipstick after filling it. By about 20 miles down the road it was obvious something is wrong. Pulled over to find oil running all down the underside. Their field tech met us on the side of the road and found the problem, drained 4 gallons, and said we were good to go. As we started to drive the oil pressure was pretty high and there was a little noise that I could notice, I was going to take it back to Missoula but after calling the mechanic told me there was no need and it was fine. When we made it to the Travel America in Spokane, the oil was no longer correct it was about half a gallon low and was leaking out of the blow by. There was also a high-pitched ticking or chirping that I was noticing right about when we hit Washington State border. We spent the night in Spokane since they don't have an ASE Certified mechanic at night, and he supposed to look the engine over today. I'm hoping I just blew a seal, but the noise makes me think it could also be something worse, like a seal got pushed further in or something. Thoughts? If anyone has a lot of experience with the 3116 motor or if anyone has done something stupid like this before, or even if you know what would obviously fail if something like this happens, I would love to be able to point the mechanic in the right direction.
Also, these guys don't know much about the hydraulic system, that's one thing that doesn't look so awesome on my truck. Pump and hand crank isn't enough to raise the cab. I'm pretty sure it's low on fluid, they just need to add fluid to the Box in front of the spare tire behind the turbo, right? Pump makes noise but doesn't sound like there's anything there, and crank just feels like there's air with no pressure behind it. When the roadside mechanic came to drain the four gallons out, we couldn't get the cab to latch because there was no pressure so we actually have a tow strap holding it in, any advice son getting it to close would be helpful. Two big guys jumping on both sides of the truck wasn't enough to make it latch haha.
Thanks!
Matt & Janey
If you overfill, it will spray oil all over itself on the starboard side. It makes a mess but it is otherwise fine to drive. Just make sure you are keeping up with the oil level and that it is ok (that the only problem was the overfill). The oil dipstick is on the port side, towards the rear of the engine. Since you cannot lift your cab, you can still get at it by lifting the mudflap thing that covers the engine. You have to kind of get your hand in there and do it half blind but you'll soon develop the knack for doing it, since it beats lifting the cab every day of the week. When you go to put the dipstick back in it can be kind of tricky, you have to get just the right angle or it won't go down the tube, it gets hung up.Thanks for the help everyone!
Thanks!
Matt & Janey
Min 15PSI at idle and max 88psi at full RPM. Anything within that is fine. And yes, everything is fine... Just like we told youAs far as the engine goes, they got oil to the right level and had me drive it for a couple hours around Spokane with a cup underneath the blow by to see if any more oil came out. I lost no oil. They sure be I was fine to drive home and said if I had any problems that they would take care of me. I called CAT to see if there's anything they could do to look over the motor and they said that it wouldn't hurt it to overfill it by that much, or that even running it at half gallon low for the 250 miles after he drained too much wouldn't hurt it either. So I guess everything is fine??
Oil pressure was always between 58 and 60 PSI consistently before the oil change. Now, at idle it's it's about 45 PSI and changes with acceleration, but does remain steady if I hold RPM steady come on the high end it's about 72 psi now. Is that normal? I couldn't find any PSI data on the motor. I thought maybe when it was reading 60 PSI before it had a bad sensor and the tech might have clean something when he changed all the filters and oil change. I know new oil also runs at higher pressure, so I'm thinking that these pressures are normal, but with the scare of blowing a seal I'm wondering if it's supposed to just stay at a solid pressure all the time like it used to.
With regards to the mistake they made in Travel America Missoula, the tech that worked on it actually worked on lmtvs all the time in the military I guess he was active duty or Reserve or something.. BUT apparently the engines they use on theirs I'll take exactly 10 gallons, he was so confident in doing it all the time that he didn't check the dipstick or show me. He was however able to get the horn and turn signals working, washer fluid, and fuel filters. Just didn't check it the important part.. the oil level!
