Tinstar
1,776
Edmond, Oklahoma
B4FAF195-A47E-4896-80F6-674431304DA4.jpg6CE7ECE3-D215-46EA-B1AC-A08181B1B222.jpg6D34542B-C2EF-477C-A26B-8ACCB9FF958F.jpg18051562-A360-4CF9-80CC-9EBBBABBFE15.jpg
Installed new winter front.
Cold here today and it does make a difference with engine and cab heater temps.
Chevybrit
Northern Pasquotank NC
This is my next project. Went to town today to drop off my inspection ticket to please the revenuers and when I came back out the starter would just clunk. The solenoid energizes but the starter doesn't turn. Look like it'll be down for at least a week by time I get a starter in. NAPA wants $300 by time they get it shipped to them and AdvanceAuto doesn't seem to know what a 24v starter is. EvilBAY it is I guess......
Had the same issue and a little service cured it ... see this
https://www.steelsoldiers.com/showthread.php?171432-Clunk-but-doesn-t-Always-turn-over
It might help save some $$
Chevybrit
I've been through TM 9-2320-289-20 Page 207 onwards and can't find any reference to some kind of mechanical valve in the exhaust ... sounds like the power valve system in my old RGV and YPVS ... Those were the days :naner:
Beandip
23
Cache, ok
What are you going to the old transfer case, I mite need it.
for now its collecting dust in the garage. Not exactly trash, but its there for in case my buddy needs it for his CUCv. I put it through some use running the 40s on 10 psi on rocks locked in the front. im surprised it held up as good as it did. either way not sure if i'm going to part with it just yet. or if i was, it would be a local thing as i wouldnt want to mess with shipping.
computer54
Nashville,TN
Just let me know I mite just drive out from TN. and get it.
FrankenCub
29
Broome Co., NY
Volvo740turbo
St.louis missouri
I finally got around to changing the water pump on my m1009 upon removal of the timing plate there appears to be a spring-loaded rod on the gear that drives the fuel distribution pump does this just get pushed back with the timing plate or is there something more to retain it I have not tried to pull it out all the way
cucvrus
10,433
Jonestown Pennsylvania
It just rides there in the end of the injection pump. Nothing holds it there but the cover and spring tension. May I suggest you change the front main seal while you have that torn down that far. Good Luck. Happy Holidays.
FrankenCub
29
Broome Co., NY
It will push back in with the plate. I will also need to replace my pump soon, getting noisy.
