Let the fun begin
Skrilex
Banned
355
Portland Oregon
Finally got her home. My first milspec vehicle. Life long dream car.
But, going against recommended advice, I bought a non runner. I like to tinker. But, don’t quote me on that later please!
so within the first ten minutes she made me bleed, okay fair enough, like an animal fresh from the pound we will take time to building trust.
First questions I have for you guys is about some fitted equipment. There seems to be a light by the shifter that is an indicator. Says T/C lock which I can only assume is torque converter lock? But this is an 85 truck with a 6.5. Does this mean it has a 4sp tranny or a modified 3sp? Look at the pic.
Also there are two cables coming up on passenger side that look sort of newer and cobbled on, with connectors loose in footwell. ANy idea what these may have been for?
Any help appreciated on this. It will be an adventure for sure. 9A30E808-A03F-4186-A157-3CBBE0E561DE.jpg700D3040-A440-46D6-9EE1-E7CAFACEA86A.jpg
porkysplace
1,487
mid- michigan
The T/C lock light is most likely transfer case lock .
Have you read this yet ?
TM-9-2320-280-10.pdf
TM-9-2320-280-10 Operators manual for the M998 series truck. June 1991
You really should read it to get know how to operate things properly.
Wire Fox
161
Indianapolis, Indiana
T/C doesn't mean torque converter in this case, it's transfer case. That should illuminate when your transfer case is in HL or L position.
The two cables are radio/electronic power cables. The 4 prong is very common for the VRC-12 series radios and others. Not sure what the multi pin unit is for.
Sent from my SM-G530T using Tapatalk
NormB
70
Cloverly,MD
Look underneath your truck at the transfer case (just aft of the transmission). If it has two wires coming off it, it's an NP 242 - i.e., newer model - and the LED should light up in HL or L(lock). Or just put the TC selector in HL and turn on power, it should light up.
Skrilex
Banned
355
Portland Oregon
Ah cool thanks. No I haven’t read an owners manual since, well, let’s just say I haven’t read it yet lol. But I will and thank you for that.
Darn about the tc lock light. Why does it look non original? I was hoping I somehow got a tranny upgrade lol.
Its going to take some doing doing before I can slap batteries in it. There’s major mech to figure out first.
86humv
500
Texas
Who ever did the T/C upgrade....must of had a dull hole saw.
The early 242 T/C came in a kit [ T/C, Wires, Light, drive shafts ].
Wire Fox
161
SO, my alternator is missing. Does anyone have one for sale or trades?
Look through the parts for sale section in the classifieds, or post a new thread to the parts wanted section. I think some guy had a 200A dual voltage unit for sale a few weeks ago. You may find that someone has a 60A unit for much, much cheaper.
Skrilex
Banned
355
Portland Oregon
Man that manual has entirely toooooo many pages. A whole page dedicated to the park brake? Ugh. Too bad I did t get to the part about wheel pressure 30 maximum before overfilling them and now they leaking. Do I have to tear the wheels down now?
NormB
70
Cloverly,MD
That 30# is for the older BIAS-ply tires. Newer ones have RADIALS and can go up to 50 psi.
Really, read the manual.
There are some peculiarities about when and where to use high and low lock and when to shift (idling, engine off, etc).
That’s in there somewhere too. Once your rig IS running, reading a bit now can greatly lessen your future pain and suffering listening to parts grinding, things breaking.
Won’t prevent busted knuckles though; mechanix gloves help, but you’ll get caught not using them sooner or later and you’ll wonder what that sticky stuff is between your fingers or where those red drops are coming from.
And please, take your rings/jewelry off while working on trucks. Believe me, ER docs (or worse, nurse practitioners) really don’t need the experience with degloving injuries or ring cutters.
But have fun. Really.
juanprado
2,886
Metairie/La (N'awlins)
30 should not cause a problem. Are they all leaking? use soapy water and see where the leak is?
On the Alt, Post a pic of your brackets & wiring. It can have a 60amp stock older prestolite unit or an upgraded 100 or 200 amp niehoff?
Skrilex
Banned
355
Portland Oregon
Oh, and t/c isn’t “tranny” it’s transfer case.
That’s in there somewhere too. Once your rig IS running, reading a bit now can greatly lessen your future pain and suffering.
Not busted knuckles though; mechanix gloves help, but you’ll get caught not using them sooner or later and you’ll wonder what that sticky stuff is between your fingers or red drops somewhere.
Okay well strange I think two of them started spouting air sounded like inside somewhere. It’s dark.
Ya I’ll slog through the novel I promise. I wish there was a version without ambulance specific stuff and etc. but hey, it’s a free factory manual so can’t bitch too much. Just seems funny like in the field maybe with bullets flying would make the reading go by faster.
Cant wear gloves for most tasks they just feel weird and slow me down. There’s a hand recovery time of a few days after any big jobs lol. But I have never been able to wear jewelry especially rings. Just can’t. I’m a stunt welder by trade so that could burnt too.
Thanks for encouragement. Just discovered the glow plug controller is missing too. :/ I may end up engine swapping and converting to 12v anyway though, so it may be irrelevant. Pulling oil pan tomorrow to see what the bottom end looks like.
porkysplace
1,487
mid- michigan
Just think if you would spent all that time you spent checking GP to see if your EUC cleared reading the manual , you would be done with the -10 manual .:razz::doghead:
Seriously though reading the TM's will save you a lot of money and time in the long run .
jackson76550
sealy tx
true story. electricity and rings don't mix as well. if you need inspiration google image search degloved finger
