dskupi01
- 5
- 8
- Detroit, mi
I went to change the filter on my 1993 AM General M998 Humvee HMMWV. Opened pan,
and filter was loose. I've done other GM transmission oil changes (4l60 I
think). For them, the filter was press fit into the pump with no
bolt.
Looking at the bolt, (see attached pics) it appears too long. I
assume the bolt should moderately clamp the filter to the underside of the
valve body. As it is now, there's play. Correct? Anyone
do a recent change? Is the bolt for assembly only & remains loose after torquing, and the bottom of the
pan holds the filter in location?
Part 13 in second pic. Shoulder is 1 5/16" and overall length is 2 3/8". Bolt is NLA from GM, or I would just buy a new one. Option B, junkyard, but I wanted to ask here first.
Also, planning on using Dextron 6.
Thanks for the help.
bolt.
