Heater hoses
Kharville
Clinton LA
I am trying to validate my heater hoses against the PS article below. Is my top hose where it should be? I can't really tell from the quality of the picture.
porkysplace
1,494
mid- michigan
View attachment 711896View attachment 711895
Are you working on a HMMWV or a M35A2 , you posted a article for the HMMWV but thread is in the deuce forum
and no mention of what truck your trying to install it on .
If your trying to install on a deuce post #9 of this thread has the correct article.
M35 hot water heater
Edit; spelling :doghead:
Kharville
Clinton LA
The article I posted is the same one you mentioned. "Multifuel 2.5 ton". It is for Deuce. Where did you see HMMWV?
frank8003
4,987
Ft. Lauderdale, Florida
Validate your heater hoses hookups by searching Steel Soldiers.
Also search for coolant filter setup with and without a cab heater.
Anyhow, here is some stuff to add to the confusion.
What not to do with or without a filter.
and pictures of what has been done with coolant filters, with and without cab heaters.
CCW filter complete 09172014.jpgCCW to waterpump original valve.jpgCCW waterpump inlet to same size.jpgcoolant filter flow.jpgcoolant filter old line plugged.jpgcoolant filter proper hookup return to pump.jpg
coolant filterwhat not to do.jpgcoolant filter with valve.jpgcoolant filter the right way.jpgcoolant filter proper way.jpgcoolant filterwith heater tee.jpg
hot water outlet vave pump.jpghot water outlet valve from where.jpghot water outlet valve from water pump.jpghot water outlet from engine.jpghot water inlet to engine.jpgcoolant filter proper way.jpgthis valve.jpg
Ain't pictures wonderful?
rustystud
3,267
Woodinville, Washington
View attachment 711901View attachment 711902View attachment 711903View attachment 711904View attachment 711905View attachment 711906
View attachment 711900View attachment 711909View attachment 711908View attachment 711907View attachment 711910
View attachment 711915View attachment 711914View attachment 711913View attachment 711912View attachment 711911View attachment 711907View attachment 711916
What ? No pictures of my set-up ? I know it looks crazy what with two cab heaters, coolant filter and engine block heater but I thought I could get at least an honorary mention ! :shrugs:
frank8003
4,987
rustystud post the link to all your heater setup pictures or post them here,
You always get honorable mention for your stuff.
Help add to the being in the land of crystal clarity a bit more.
rustystud
3,267
