rustystud
- 2,815
- Woodinville, Washington
Honestly, just get the proper test procedure and show it to the tester each time you go in. No need to adjust anything. Just do the test correctly.
Like I said originally, the testers don't know what their doing.Found this....
http://legacy.azdeq.gov/function/laws/download/1998/diessnap.pdf
A cut and paste from R18-2-1006, section H,
H. In area A, the inspection test procedure for diesel-powered vehicles shall be as follows:1. A diesel-powered vehicle with a GVWR greater than 8,500 pounds shall be tested with a procedurethat conforms to Society of Automotive Engineers standard J1667, February 1996, incorporated byreference and on file with the Department and the Secretary of State. This incorporation byreference contains no future editions or amendments. A copy of this referenced material may beobtained at: Society of Automotive Engineers, 400 Commonwealth Dr., Warrendale, PA 15096-0001. The procedure shall utilize the corrections for ambient test conditions in Appendix B ofJ1667 for all tests. The test results shall be reported as the percentage of smoke opacity. Emissionspass/fail determinations are as follows:a. Vehicles powered by a 1991 or later model year diesel engine shall fail if the J1667 finaltest result is greater than 40%, unless the engine family is exempted from the 40%standard under subsection (e);b. Vehicles powered by a pre-1991 model year diesel engine shall fail if the J1667 final testresult is greater than 55% unless the engine family is exempted from the 55% standardunder subsection (e);c. The engine model year is determined by the emission control label. If the emission controllabel is missing, illegible, or incorrect, the test standard shall be 40% unless a correct,legible emission control label replacement is attached to the vehicle within 30 days;d. Any vehicle that exceeds the appropriate standard fails the emission test. Beforereinspection, the vehicle shall have a low emissions tune-up as described inR18-2-1010(G);
We call them diesel engines the correct name is compression ignition engines. Regardless of the fuel type the testing is the same cut your fuel by 50 percent with mogas and your exhaust will dramatically clean up. I would not go straight gas as it can score the cylinder walls and it will be hard starting. I was in a pinch in Korea once and had to run straight gas in one it worked but was under powered I was amazed that there was just about no smoke though.Also, do not forget that your multifuel can run on fuels other than diesel. I went to my emissions test (long story) with a tank full of regular gasoline. Much less smoke.
Note that it is YOU who tells the DMV that this truck is a Diesel powered vehicle. Says who? It could equally be a gas powered truck. Runs fine on gas.
In my case, they could only test diesel trucks, not gasoline ones, so....
Mine passed as it always has. It's never been an issue of passing. The problem has always been that doing the test as described in SAE J1667 (which is the procedure AZ follows) requires me to "move the throttle to the fully open position as rapidly as possible". When I do that, it produces a very short lived, but significant soot cloud that then coats the opacity tester being used and causes the zero value of the tester to drift too much between the three repetitions.So what was the out come did you get it inspected?
