FYI: Wheels and tires
papakb
1,185
San Jose, Ca
An issue I had with the 12 bolt wheels was that I wasn't torquing them properly when I changed tires. I used a long 1/2" breaker bar and tightened them to where I thought they felt tight. What was happening was I'd be driving down the road and all the sudden I'd hear what sounded like a pistol shot. It didn't matter what speed I was going or if I was on a straight or curve section of road. Bang! I'd get out and would see 1 or two studs broken off at the wheel face.
What it turned out to be was uneven torque on the wheel bolts. I aired down all my tires and retorqued all the bolts in a two step process, I torqued them to 75 pounds and then to 110. Since doing this I haven't broken a stud so be aware that it's important to torque them properly. In the long run I don't know whether I was overtorquing them or undertorquing them but when working on your wheels and tires keep this in mind.
Wire Fox
161
Indianapolis, Indiana
But seriously, always best to hit the lug nuts with a torque wrench when changing tires!
I loved that the last tire shop that touched the wheels of my cars proudly used torque wrenches...set to the wrong spec. Literally overheard "What's the torque on this one?" "Just set it to 100 and move on!"
Thanks guys, 22-28 lbs over spec.
Sent from my SM-G530T using Tapatalk
98G
Former SSG
4,441
Thanks for the PSA.
Like many people, I didn't take it seriously either - " good enough is good enough" . Um, no. In my case I broke wheel studs on a 5ton. Now I know better, from personal experience.
Let's hope others learn from our mistakes and avoid the personal experience themselves.
porkysplace
1,493
mid- michigan
A lot of tire shops like using torque limiters on air guns , but you can't beat a quality torque wrench .
Action
1,558
East Tennessee
100 isnt over for the final torque on 12 and 24 bolt rims.
papakb
1,185
San Jose, Ca
Wirefox, if your using 85# as your wheel torque spec then your torquing your wheels to the old 8 bolt bias tire spec. Doing an search online for HMMWV wheel torque specs takes you to several sites that specify 110# for the 12 bolt wheels with radial tires but I just took a look in the new TM and came up with 125#. My wheels are all torqued to 110# and I haven't had any problems in the last 3 years. That 125# spec might be the current spec for the grossly overweight HMMWVs with full armor packages they drive today.
ryanruck
46
Cincinnati, OH
This reminds me... I know I posted it to a 24 bolt thread a while ago but, since it's a little hard to find newer TMs with info on the 24 bolt tightening pattern, here's the section on the bolt tightening pattern and torque specs for both the D and E rated 24 bolt wheels.
View attachment TM 9-2320-387-24-1 -- 24 Bolt Wheel Addendum.pdf
Wire Fox
161
Good info, but my post earlier was about the bad work a shop did on my Dodge Dart, not my HMMWV. Much lighter duty application!
DatGuyC
22
Essex, Maryland
Once I realized those nuts on the wheels were lock-nuts there was no way I was gonna do them by hand. Cinched them all down in a star pattern with the impact and haven't had a problem and I've driven my truck over 10k miles. These were 24 bolt wheels so that might help spread the load on the studs. One trick I used to make sure the two halves of the wheels were centered was to use 4 of those tapered lug nuts to make sure the holes were centered around the studs. I got the face tight but not all the way seated with the normal lock nuts and then tightened the 4 tapered nuts lubed with anti-seize to keep it centered. I'd go around in a pattern of tightening the normal nuts then the tapered ones and back to the normal ones till it was bottomed out. Then just backed off the tapered nuts and put the normal ones back on.
gringeltaube
Staff Member
2,523
Montevideo/Uruguay
.... One trick I used to make sure the two halves of the wheels were centered was to use 4 of those tapered lug nuts to make sure the holes were centered around the studs.....
And what if I told you that centering the holes on the studs is no guarantee at all, for lowest radial runout of the inner wheel section?
Easy to confirm, if you mounted just the wheel - no tire, on a hub and spun the whole thing. I bet you'll be surprised...
G.
