Low air alarm just started working?
Givinup
Oklahoma City
Something I did recently caused my low air alarm to start working again. I had hoped it had been removed / disabled in the field, but after nearly ****ting my pants in a closed metal rv storage unit upon start up, I've somehow caused it to work again. It was the first time I've ever heard it, and at 11:00 PM unexpectedly in a closed dark storage unit wasn't ideal.
I recently added hydraulic fluid as the truck was very low. Would this have caused it?
I've started it with low air and after much longer period of sitting to now alarm..
In any case, how do I disable it, or at least muffle the buzzer on it?
98G
Former SSG
4,252
On the 939series trucks some tape over the buzzer works wonders.
You may want to check legality. In some jurisdictions disabling it or operating the truck after it has been disabled is illegal. YMMV.
bikeman
501
Ft. Bragg, NC
Shove your hand over it for the 3 minutes it takes to build pressure.
I think you can get some foam or something and tape over it or put it under the protector. But my method was always just either keep my hand plastered over it or get out of the cab and walk around the truck until it builds (maybe not the best idea, but saved the ears)
Givinup
Oklahoma City
It only takes about 20 seconds to build the pressure, but it sure is annoying. Was hoping for a quick way to unplug. Will do some googling...man I wish it were still broken.
porkysplace
1,487
mid- michigan
It gives you time to do your daily pre-trip inspection.
kblazer87
308
southeast Indiana
Why would you want to disable a system that could save your life? Yes it's annoying. It's supposed to be, to get your attention before it is too late to do anything about it.
Givinup
Oklahoma City
For the next 8 months I'll be working on the truck in a metal shop that's 14 ft wide, 20 long. I'd like to disable it so when I start truck truck it's not incredibly loud when I'm not going anywhere
porkysplace
1,487
mid- michigan
No shop air to charge the system with ?
kblazer87
308
southeast Indiana
Ok, that is a horse of a different color then. Easiest way to charge from shop air is get a glad hand and plumb it up onto a shop hose. If you were lucky enough to get the inflation hose with your truck you can use that one with a regular quick connect in place of the inflator end.
