aleigh
- 52
- 48
- Phoenix, AZ & Seattle, WA
My left rear blinker was intermittent and then finally gave up the ghost. Tail light seems to work fine. I haven't checked the brake light yet but I will as soon as I have a person to look at it. I thought that this was just a defective light unit or a bad ground until I realized it's not lighting the trailer lights either, which lead me to do some troubleshooting, and it is not energizing the trailer 24V turn signal relay for the left side. I swapped relays with known good just to be sure. So now I suppose the problem is in the dash somewhere.
I went through the TM but funny enough they don't have a troubleshooting procedure for rear-only turn signals (but they do for front turn-only problems). I haven't started dragging myself through the electrical schematics yet, but I am posting in case someone else has run into this problem already and can steer me the right way. My guess is the flasher module is okay since the fronts work?
EDIT -- Solved. Dashboard warning light module cable was loose.
