- 6,855
- 680
- Stratford/Connecticut
You can count on 12kw from a good running well maintained 803a. 12000w / 120v is 100amps. Or 50 amps at 240v.
Looking for a commercial unit has been disappointing. To pass inspection for the entire job I need a UL listed unit. I figure if I am going to spend over $10K for a commercial unit I am going to get the whole job inspected. (I am hiring an electrician to install the ATS and Load Shedding kit. That job will be inspected with my portable generator.)Find one in the size you need. Dosnt have to be military surplus to do the job.
That was my first choice except I don't have NG but wanted to go LP. Can't find a legal place to bury or place a 500 gallon LP tank that a truck can actually reach. Thought about manifolding smaller cylinders but ran into issues there as well.I have moved several low hour commercial Kohler NG units that are 30kw units 240/120 single phase or 3 phase that sell for less than 6k. No wet stacking!
Have you called the LP suppliers in your area? Around here most delivery trucks have at least 100' of hose on the reel. Some can reach 150'.Can't find a legal place to bury or place a 500 gallon LP tank that a truck can actually reach.
Yeah, 110' was the best I could get and that's about 15' short given my property layout. With LP around $3.50/gallon and ~$5,000 in up-front costs, I'm good with diesel at this point.Have you called the LP suppliers in your area? Around here most delivery trucks have at least 100' of hose on the reel. Some can reach 150'.
