Coonhunter
- 0
- 0
- Shippensburg, PA
I was out hunting I cast the dogs loose and when I was going through some mud it felt like the transmission was slipping I stop the truck and went to go again and I thought maybe that I did not release the E break or something stupid I drove the Humvee for about a half hour before this I shut the Humvee off and walked the dogs and came back out when I want to leave the transmission started slipping for sure so I put it in four Lo it got it moving for a little bit and then it slipped out to a complete stop put it in neutral and check the transmission fluid fluid level was good but the fluid seems to be almost clear with not a lot of red I do not believe there is water in it but anyway I let it sit for 45 minutes and went down the road with no problems until I arrived home a half hour later and it slipped a little bit when I went up my driveway it went into reverse fine any suggestions ideas on what the problem may be things I should try first before getting a mechanic??? The transmission and engine was rebuilt in 2009 and supposedly after rebuild sat around until I purchased it
