Desertshark
- 5
- 18
- Albuquerque nm
So I have a 931a2. Over the last week I have noticed that my motor has sprung a bad oil leak. The leak is in the front of the motor. At first I thought it looked like but was leaking front of oil pan. So made sure all bolts on pan where torqued to 18 ft/lbs. None where under that am out. Next retourqued the drain plug to required 60 ft/lbs. Took to car wash got front axle clean of all oil to see if fixed. Got to work today all is coated again with fresh oil. Anyone have some insight to what is going on here ? Livebin southwest night not too bad. Average low is 25 degrees. Truck has almost 15k on it now.
