- 3,829
- 5,941
- MA
Where did you source this material? Might be time to take a trip to the local Lowes and see if they sell perforated sheet.I was putting batteries in my new 2006-803A and noticed that the foam that goes over the lower drain hole sits about an inch above the floor. My 2004-803A has the foam right against the floor. I don't know if it was installed improperly or if it is a design change but it certainly won't keep varmints out [I doubt the foam right on the floor will either for that matter]. I lifted the generator up and there is a 6x6 hole. I could get my fingers in all the way around. So in addition to making up inserts for the side vents like I did for my old 803A [see photo in previous post] I installed a piece of perforated stainless steel I had to keep the mice and squirrels outView attachment 670050
