MEP-802A MEP-803A battery hold downs
Daybreak
2 Star Admiral
771
Va
Howdy,
MEP-802A Battery information
uses a group 51R battery
6160-01-431-4547 88-20056 battery tray
OVERALL LENGTH 11.000 INCHES NOMINAL
OVERALL HEIGHT 1.500 INCHES MINIMUM AND 4.390 INCHES MAXIMUM
OVERALL WIDTH 5.750 INCHES NOMINAL
MATERIAL PLASTIC, POLYETHYLENE
MEP-802 battery tray.jpgMEP-802 battery tray 1.jpgMEP-802 battery tray 2.jpg
MEP-803A Battery information
uses a group 34 or 34/78 battery
6160-01-431-4546 88-20516 battery tray
OVERALL LENGTH 10.370 INCHES NOMINAL
OVERALL WIDTH 6.880 INCHES NOMINAL
It looks similar to the MEP-802 tray ,but slightly larger
Both MEP-802/803 use the same bolts, and hold down bracket
5306-01-367-7777 88-20060 bolt, hook
6160-01-476-4365 88-20055 bracket
MEP-802A battery
MEP-803A battery
Daybreak
2 Star Admiral
771
Va
Howdy,
The trays look similar, but they are different sizes. The parts manuals also do not jive with the proper fitment on later TM's
MEP-802A 88-20056 battery tray
MEP-803A 88-20516 battery tray
Farmitall
276
Eubank, KY
Where are the simple rubber flap type terminal protectors available from?
Doing a bing search, every possible type comes up in images other than the type pictured above, and the same type I've seen used on many trucks.
Asking in anticipation of putting new batteries in my soon to be delivered generator.
Thanks
Light in the Dark
5,933
MA
If anyone is looking for the battery hold down sets, some just appeared in the classified section of SS
