BenRoberts
Certified insane
- 1,367
- 208
- 63
- southwest/ohio
I'm buying stock in preparation H after how long you were in that seat
You my friend, are hard core. I did 60 miles round trip in my M817 dump with 8 tons of rock (only one way) and an 18k excavator on the trailer and was spent! Between the noise and constant shifting attempting to maintain any sort of reasonable speed on the hills, I couldn't wait to get out of that cab! Time for a turbo and more cab insulation.Left Memphis on January 18th. Got home the evening of the 2nd. Logged nearly 9,500 miles in that span. Was a long two weeks. Had an exhaust clamp issue that i fixed. Started having an oil leak from the head gasket it appears but it is intermittent. Had a loose connection on my alternator cable causing a spiking issue and a loose coolant hose clamp. Other than that she ran like a champ. She ran 3 trips from northern VA down to Albany and back. Then as far out as Fargo and back down. I left Hagerstown, MD about 2pm on Saturday and I was in Fargo at 1pm Monday to drop off. The temps were colder so i left her running. She ran continuously from 2pm Saturday until 5pm on Thursday. She did surprisingly well. Had to use my heater alot and even my air conditioning at some points. She had a headwind all the way west and coming back down mostly. Averaged around 6mpg loaded with 1600s. So imagine how much diesel I went thru. It killed my top end OD but did well in direct (15th)
Of course everyone likes pictures. As far as idle/burn time. At 8 hours idle she used about a gallon/hr.
On the one dozer pic she looks to be squatting pretty bad. I was actually parked in the middle of a low spot so it looks bad.
Did get home last night and this morning got the Wabco air dryer installed along with the measurements for the HEMTT case and I got some hydraulic cylinder mounts made up for my trailer ramps.
Grendel has his for sale. Member gofastboats has one for sale in Dayton as well. It just sucks with the deck height of 4'Got rid of the M931 and dreams of a RGN trailer...now want one like Wes is using. Dam green disease.
Wes, Have you ever seen a lower height deck that will hook to pintle hitch? We need capacity for a Cat excavator about 25K#.Grendel has his for sale. Member gofastboats has one for sale in Dayton as well. It just sucks with the deck height of 4'
I have a frame 25' that I was going to build a fold down gooseneck, but now with the tractor truck gone, that plan is off the list.
Free of grease? Ain't it all supposed to be grease packed including the boots to a extent?What are you looking for? Make sure everything is free of grease when you put the boots back on.
Yes everything needs to be greased thoroughly pretty often.Free of grease? Ain't it all supposed to be grease packed including the boots to a extent?
Sent from my SM-G900V using Tapatalk
As per recommendation it’s good to see you aboardHey fellas , new to the page here . Was recommended here by a few guys on the M939 FB page . In the process of doing my boot seals and just wanted to say hi and i look forward to all the good info this page can provide ! Thank you in advance for any help or constructive criticism you may be able to provide me with !
https://youtu.be/Q3Z6_ySV8D0Hey fellas , new to the page here . Was recommended here by a few guys on the M939 FB page . In the process of doing my boot seals and just wanted to say hi and i look forward to all the good info this page can provide ! Thank you in advance for any help or constructive criticism you may be able to provide me with !
If there is any grease in the grooves at all, you will need 30 hands to get the boots to stay in place. Imho the 939 trucks should have grease on the bearings and thats it. Will it hurt to have everywhere? No. Is it supposed to be there? No. Will it help fight rust? Sure.Free of grease? Ain't it all supposed to be grease packed including the boots to a extent?
