What brake fluid are you using for hydraulic brakes?
US6x4
2,242
Wenatchee, WA
It's time for me to replace the rubber brake lines and flush out the old fluid that might have been mixed by the PO. The TM only states "non-petroleum" product and I'm not sure what that would be called today. DOT 5?
I have read of some guys converting to DOT 3, but I don't want to mess with incompatible fluid versus rubber parts in case they don't play nice. So what is the go-to factory style brake fluid for my M813?
doghead
4 Star General /Moderator
1,178
Dot 5
sandcobra164
291
Leesburg, GA
Dot 5, search online to find a vendor if you're taking on a project like you stated and need a gallon or more of fluid. Quick top off levels of Dot 5 can be found at you're local Harley Davidson shop as they use it as well but it's expensive if you break it down to dollars for ounce.
US6x4
2,242
Wenatchee, WA
My TMs denote nothing with "DOT 5" in their verbiage, but it was published in 1972 which may be prior to that classification name.
So 2 questions now: how much do I need for a complete flush?
And what size is the master cylinder plug threads so I can get the correct adapter for the pressure bleeder? Something like 3/4 NPT or straight thread with o-ring?
162tcat
46
Washington
Mine came with DOT 3 from the local government (wsdot). Flushed it again with DOT 3 after changing all soft lines and it's still happy. If you have DOT 5, I'd stick with that. If it's like mine, might as well stay with that.
frank8003
4,985
Ft. Lauderdale, Florida
Put the master cylinder part number or NSN into Part Target and read everything about it?
Oops, that didn't work!
http://www.parttarget.com/2530-00-7...&searchoption=sku&originalsearchtext=12356931
...........so just guessing from here probably 1/4" NPT.?
If you are going to install/use a pressure brake bleeder than you should read this. Especially the first part of page two if this applies to your truck.
View attachment master cylinder remote roscommon nn17.pdf
US6x4
2,242
Wenatchee, WA
Thanks for all of the good info! I searched the forum numerous times but must not have had the right key words. That 'part target' site is a new one for me and I'll keep an eye on that one.
US6x4
2,242
Wenatchee, WA
Well I drew a sample of fluid from the MC and it could be bad news...20180204_102950.jpg
This mixture is half water / half brake fluid from MC after an hour of sitting and there is zero separation. I have a bad feeling the PO simply added "brake fluid" from the parts store (DOT 3) into the MC. He did mention bleeding the brakes previously so who knows what is down stream.
From what I've read here I shouldn't panic until I know what type is in the wheel cylinders?
162tcat
46
Washington
Well I drew a sample of fluid from the MC and it could be bad news...View attachment 717642
If it's been changed over DOT 3, it's plenty easy to continue flushing the system with the same DOT 3 to make sure it's fresh and clean. Mine came that way and I flushed it one more time when I got it as preventative maintenance. Lots of Miles hauling heavy without issue. Was hauling gravel and the excavator yesterday, left the scale at 49k after getting loaded up. DOT 3 stops her just fine and it's much more affordable to keep up on regular brake fluid maintenance such as flushing or wheel cylinders due to availability and cost. Just change all of the rubber lines(5 of them) before you invest in any fluid no matter what you use.
Sent from my LG-M210 using Tapatalk
red
25
Eagle Mountain/Utah
Dot 5 will separate on top of Dot 3 and water, so if there is any 5 in the system (assuming the truck has been sitting) then it would be in the sample you pulled from the master cylinder. So the truck has most likely been supplied with dot 3 fluid.
Either fluid works fine in the regular driving world, just make sure it's clean fluid and not intermixed.
These trucks don't have a sealed brake system (master cylinder vents to outside air by design) which allows moisture into the brake fluid. More humid/wet the environment the faster this happens.
162tcat
46
Washington
In addition to what he said, DOT 5 will also lose its purple color over time and look more gray like the sample you have. It's likely a mix of DOT 3 and 5 as stated above.
US6x4
2,242
Wenatchee, WA
Ok, here is a sample from the right rear wheel cylinder with NO water added. Lots of tiny bubbles initially, but now the bubbles are just in the top. Do you think this is a mix of 3 & 5?
porkysplace
1,493
mid- michigan
162tcat
46
Washington
Should I add water to learn more?View attachment 717663
That sample just confirms that the system is overdue for maintenance and a flush. At this point, you'll be replacing all of the fluid so use whichever you want. Are the brakes working good currently? If so, your MC and air pack are probably fine so replace the rubber lines and flush flush flush. This is also a good time to adjust all of the shoes.
US6x4
2,242
Wenatchee, WA
162tcat - I am planning to do everything you mentioned. My 5 rubber lines should arrive this week and will get replaced. The brakes worked well enough when I last drove it although not until the last 2-3" of pedal so I plan on doing the minor adjustment to the shoes.
Now, in terms of sequence what should I do? Replace the rubber lines and then flush everything out? Remove old lines, purge all fluid, then install new lines and flush & bleed? Install new lines and then flush & bleed? I'm not sure what will work best.
US6x4
2,242
Wenatchee, WA
I added water to the last sample I posted and most of the fluid has moved to the top. It seems that the fluid from the wheel cylinder is mostly dot 5 with a little dot 3 in there.
