- 1,178
- 389
- 83
- Guymon, OK
is this the sound you like on a 30k?.... And yeah, what a lovely sound.
https://youtu.be/eYIebmttjZs
or more like this sound, 33kw shock load
https://youtu.be/CH9esn3EOdk
How you doin over there in Germany Guy ??That's it!!!!!!!!! Brings back so many memories. Spent many a night asleep on top of one of those babys, just to be close in case there was a problem. Warm too.
How many kw is your heat?
You dont have any sump pumps or a well?[/
Its 20kw. No sumps, community well.
That's rough. I don't think there's any single phase MEP solution for your needs. I imagine you would end up paying more for a generator large enough to run that heating system than you would adding an non-electric heat source.Its 20kw.
See post 17, 1800 said earlier.is this the sound you like on a 30k?
So with a need of 20kw, 005a is rated at 30 3ph, do the dogleg wye mod and you get 27-28kw 1ph. Dogleg wye mod will only work of 12 wire generators. So no 800 series
https://youtu.be/Mb8pcERIMgo
you might not have to look very hardThanks for this very informative video 155! Except now, I will be on the lookout for one of these 3PH generators! Good stuff.
there are many 005's out there, you probably wont have to look very far. Many are upgrading to the 8xx series, they are out there.Thanks for this very informative video 155! Except now, I will be on the lookout for one of these 3PH generators! Good stuff.
