HMMWV TCM Schematic
wildchildsteel
el paso, tx
I am looking for the schematic for a TCM on a HMMWV. There is 2 grounds on the J2 diagnostic port. I need to know which one is the chassis ground and which is the signal ground. Pin A and F is the grounds.
wildchildsteel
el paso, tx
Thank you for your response. Yes I have the schematics to. I see that you are correct, however if you look inside the TCM box you will notice that either pin F or A goes directly to ground in the box. The other ground will tie into the big harness of the TCM. The TM's do not cover the wiring inside the TCM box. It only shows the pins on outside of the box. I do not have one laying around to take the cover off. j-2.PNG
https://www.ebay.com/itm/Used-Trans...m=322775244013&_trksid=p2047675.c100005.m1851
https://www.ebay.com/itm/Used-Transmiss ... 0005.m1851
