- 7,058
- 148
- 63
- Mid Hudson Valley NY
The Hawker/Armasafe AGM batteries are different ball games when charging them. There are threads about them with lots of good info on here.. They like to be zapped with high amps to recover.
Never said it did cover AGM's and the OP never said he was using AGM's and by far there is more standard wet lead acid batteries in use in our trucks than there is AGM's and so it is very good info to know besides all the other good info in the pdf posted as it doesn't just talk about lead/acid batteries. So if you want to share info on the AGM type batteries post it up like I did above for the standard batteries in interest of helping everyone in the long run.That info doesn't cover AGM batteries, which are 100% different than lead acid types with regards to charging them. Check the TM on them.
The HASP has an indicated capacity of 120 ah, so I maybe could charge one bank at a time (presuming they weren't at 0%), but I like the fact that he green-lighted using this as a maintainer without having to pull them, once I got them back up to snuff.With your set up the battery bank is 24V and 240Ah. The series set up increases the voltage to 24V and the parallel set up increases the Ah capacity. It is a little large for the G7200 in 24V mode as the charger is only rated to 115Ah in 24V Mode and 230Ah in 12V mode. A better charger to charge the entire battery bank at once would be the GEN4. The batteries can remain connected in their systems and each battery would have its own charge lead. So the charge would be healthier for each battery, and the system would charge much faster.
You could use the G7200 to maintain the 24V system once the alternator of the vehicle charges the battery bank up. The G7200 should be able to maintain the charge level and you could leave the batteries connected in the series/parallel system in the vehicle.
Thanks for the confirmation!I went with the suggested NOCO Genius 4.4 Amp 4-Bank UltraSafe Smart Battery Charger and after two years of use, no doubt the best battery charger system. Originally I was disconnecting the battery cables from between all four batteries and come to find out that was unnecessary. This battery charger allows you to connect clips directly to terminals without removing anything. If the batteries are completely dead or around 7 registered volts after sitting long term, this battery charger will take about 9 to 12 hours to completely recharge all 4 batteries. You can leave the NOCO 4.4 Amp 4-Bank charger connected 24/7/365 and the Trickle Cycle recondition and keeps scale build-up off of Lead Battery Plates as well.
Could you elaborate?You are better off charging each battery separately with a 12v charger.
I use two 12v charger/maintainers (Battery Minders 1500) because each battery is its own unit. If one battery were to drop lower due to internal differences of that particular battery (older, bad cell, etc.) then its dedicated charger detects that and it gets the appropriate charge while the other battery remains in maintenance mode. Also, the Battery Minder I use has automatic desulfator cycles and one battery may need to be de-sulfated whereas the other battery may not need it. Its my understanding that by using a 24V charger on two 12V batteries in series you could potentially run the risk of overcharging the good battery. However, the newer ones may be smart enough to detect that. Maybe someone else who has one of the more recent smart 24V chargers can elaborate on that aspect.Could you elaborate?
