Kellyboy
- 0
- 6
- Milton, VT
It has been a miserable cold couple of months in the north east and my m10008 has been down while installing a lift in between freezing temps. I start it once a week and it always fires up and runs great even when below zero. I went to start it last week at 0 degrees and it fired right up, ran for a minute, then sputtered a couple times and died. It would not restart so I figured it was gelled up. Trying to start it today at 34 degrees with no luck. I can see fuel in the line going to the lift pump and have verified the glow plugs are operating properly. What I am wondering is if you have a gel up is it normal to have to kill the new batteries in order to restart after thawing? Also my ip does click when I reconnect the pink wire.
