dannyd2450
- 3
- 8
- miami / florida
I am typing this from my phone and cannot access the TM's, anyone have the interior dimensions of the bed (with drop sides /gate up)?
You don't even have to search for that , just open the 5 ton forum , imagine that.168"X87.5" per the stickyhttps://www.steelsoldiers.com/showthread.php?121897-Internal-Bed-Size-for-M923
Well it looks like you need to get a moderator to make a new sticky , but most likely the next guy to measure it will come up with something different too.pork that is really not helpful and also wrong, it may have been better to post nothing at all.
how would you know to search the forum if you have never used this site? and if you are out figuring and need to know the size again most people are going to do a google search.
as for the correct size.
m923A2 bed dimensions
sides up = 88 1/8 in.
sides down 92 1/8 in. to edge of sheet metal, the bed frame is about 1/4 wider below sheet metal top on both sides.
bed length = 187 7/8 in.
the tail gate does not change the size, it does not sit over the bed the way the sides do, but rather is hinged pasted the end.
Make sure you use the same tape measure when building your tank. The measurements in the sticky are several feet closer to being “correct” +/- 1/2”......as for the correct size.
Yep , his 187 7/8 measurement would make a 14 foot bed, 15 and a half feet long . He must be using a harbor Freight tape measure.Make sure you use the same tape measure when building your tank. The measurements in the sticky are several feet closer to being “correct” +/- 1/2”...
