M1028 Fuel tank upgrade
zoto6ixty
Pensacola, Fl.
M1009 Blazer Fuel tank upgrade
Has anyone ever tried to use the larger fuel tanks from a suburban? I have called around and found one from a auto recycler in my area. They tell me that the blazer and suburban share the same tanks. Any thoughts? I'm particularly concerned about ground clearance issues. Thanks
nyoffroad
687
Rochester NY
It's been a looong time, but IIRC it does fit BUT you will need the burban tank straps and it will hang down lower. I also seem to remember that GM offered the 20 gal and a 30 and a 40? gallon. Not really sure as its been years.
zoto6ixty
Pensacola, Fl.
Thanks. The one I have found is a 30 gal. Tank and they have all the hardware to go with it. As you said, the tank must hang lower than the smaller one so I guess I’ll have to give it a try.
porkysplace
1,487
mid- michigan
Okay so shouldn't the name of this thread be M1009 fuel tank upgrade? Not M1028 which is totally different.
Sent from my SM-G930V using Tapatalk
I would like to see a 30 gallon suburban tank stuffed between the frame and fender in place of a M1028 tank.
