- 170
- 22
- 18
- Abilene, Texas
I searched the forum on "hard transfer case shifting" and found a lot of good discussion on the topic. Maybe what I am experiencing is normal operation, but thought I would ask the question again. I'm not sure that I am having any problems but here's how my truck acts when you shift from high to low in either direction. First, it seems to shift fine if you are rolling a little or moving within the speed range limits. I wouldn't say that it is always a super smooth process. Of course, you must shift into 'N' first, then press and hold the actuation button for a couple of seconds, then pull or push the shift-lever in a easy fluid motion feeling your way through neutral to high or low. It's not always perfect shifting but probably the nature of the beast. So... the hard-to-shift problem I am asking about is when the truck is barely moving, or not moving. Usually shifts ok if I'm barely moving, but a little more difficult. If the truck is not moving, then it's kind of a "roll of dice" to get it to shift somewhere from being stuck in between high and low. I never force it. When I get in the stuck position, I just feel for that sweet spot then it shifts right in. I usually have to cycle the transmission in and out of gear a time or two, to get things back into sync. I need to review the shifting procedures again in the TM, but haven't yet. I think my M818 acts pretty much the same way. It's on jack-stands right now so I haven't been able to compare the two.
So, is what I'm describing normal? Any maintenance suggestions?
