Kellyboy
- 0
- 6
- Milton, VT
Just finished a 5" lift on my 1008. Had to drain all the fluid from my steering box to swap out the sector shaft with a 2WD one for crossover. Left it on jack stands and set the play properly and steering was nice and free until I started it. Figured I would need to add fluid to the master after starting it and a good back and forth with the steering wheel. The steering got hard as soon as I started it and cycled the wheel a bunch of times. No change in the master fluid level. Went to test drive and the brake pedal is hard as a rock and barely any brakes. I would think the pedal would be squishy if anything. Don't know much about the hydroboost but hoping someone can point me in the right direction. Thanks
