162tcat
- 46
- 28
- Washington
Remove old lines and drain any fluid that you can out of the system, most will come out when you pull the lines. Then fill the master cylinder and start bleeding. Mine wasnt too bad but I ended up doing it twice over the course of about a month since I replaced the lines after my first flush. Second time it looked real good when finished. Use the money you save switching to DOT 3 to replace any wheel cylinders that look wet inside of the drum.162tcat - I am planning to do everything you mentioned. My 5 rubber lines should arrive this week and will get replaced. The brakes worked well enough when I last drove it although not until the last 2-3" of pedal so I plan on doing the minor adjustment to the shoes.
Now, in terms of sequence what should I do? Replace the rubber lines and then flush everything out? Remove old lines, purge all fluid, then install new lines and flush & bleed? Install new lines and then flush & bleed? I'm not sure what will work best.
If you search on here, there are lots of great methods for a power bleeder that makes life a lot easier so you're not constantly filling the MC
Sent from my LG-M210 using Tapatalk
