agazza2
- 31
- 28
- Ahwatukee, AZ
Purchased one of the HMMWV AC Kits and installed this system in my 1984 M915A1. I did mine slightly different than reb87 with the same kit. The HMMWV kit is the same as the one for a M915A1 with a few exceptions: AC bracket, brackets for roof mount are about 1" narrower and do not fit the roof in the correct spot.
My requirements for this install was to retain the spare tire, and be able to mount the evaporator in the same position as the kit for the M915A1 install instructions. This would give me room behind the seat to store over the road items. The install went very easy and only additional item I needed to purchase was 4' more of #6 Red dot hose. I ended up ordering 2 AC Compressor mount brackets. The first from AP Air, prior to finding the original bracket from Red Dot RD-9-10055-0P.
I used most of the parts from this kit for my install with a few remaining HMMWV parts that I will list for sale, along with the AP Air compressor bracket for the NTC-400 motor in the classifieds. Today I took the truck down to ThermoKing of Austin TX (a Red Dot Distributor) for the AC system to be vac'd down and charged. They also did a nitrogen charge to check for any leaks. The system takes 4.7lbs of R134 freon, and definitely blows very cold. I think only low blower speed will be utilized. I am very happy with this kit, which would also be a great one to install in a M35, or M923/931A2 series truck. Red Dot and AP Air makes a great assortment of brackets for all the motors. Now for a few pics of my install.
![20130921_155505.jpg 20130921_155505.jpg](https://www.steelsoldiers.com/data/attachments/312/312359-ff657190e06ea1fe0ac3e0e4fa042211.jpg)
![20131003_185015.jpg 20131003_185015.jpg](https://www.steelsoldiers.com/data/attachments/312/312362-24d02f9b27db1e4a944a0b533c0178ec.jpg)
![20131003_180104.jpg 20131003_180104.jpg](https://www.steelsoldiers.com/data/attachments/312/312361-52a8375ad9007a77c9af775431e2274e.jpg)
![20131003_185025.jpg 20131003_185025.jpg](https://www.steelsoldiers.com/data/attachments/312/312363-dfb86bdf1eca3272a69364ca9d9ab97b.jpg)
![20131010_170227.jpg 20131010_170227.jpg](https://www.steelsoldiers.com/data/attachments/312/312364-c7a75c1bbb8b21452e645f68e438567b.jpg)
![20131010_170237.jpg 20131010_170237.jpg](https://www.steelsoldiers.com/data/attachments/312/312365-9e3219c67c68481412b88b97c7793a1c.jpg)
![20131010_171815.jpg 20131010_171815.jpg](https://www.steelsoldiers.com/data/attachments/312/312366-f9aaa70fbafc0c962c15704c6a170377.jpg)
