- 544
- 276
- 63
- Eubank, KY
Seems it doesn't want to come up to anything higher than 130 degrees.
Exhaust gasses are hot, can't hold a hand above it 6 inches for more than a second or two.
I drained the coolant, removed both radiator hoses and cleaned all the connections of corrosion and replaced the lower hose. I used a very light coating of Indian Head gasket shellac on the inside of each hose end. No leaks.
Filled the system 50/50 water and Prestone anti freeze. Started the set and let it run for a little over an hour and it just won't get any hotter.
Any ideas? Thermostat stuck open maybe?
