74M35A2
- 317
- 83
- Livonia, MI
You could also build a quick gantry out of 2x4's over the engine, for cheap, and quick. Go 3 on edge across the top as a beam, she'll hold just fine to lift the head, maybe even just 2. Make it extra wide on one side, and use an old roller skate as a trolley on top of it. Leave the center board up a pinch higher to make a track for the skate to stay on and guide. You can get pretty creative on stuff when working alone, you'll get it done. Some will bark this is dangerous or not to suggest such, but when alone and trying not to buy a forklift, it drives you to consider other ways that will work. Just don't be under it.
Invite your friends over and burn it when you are done so your neighbors don't have to look at it. Could put together a really strong one for less than $20. Get the skate from Salvation Army.
