M35 insulator mounting for all M series headlights.
MuleMac01
Military vehicle collector
158
Las Vegas Nevada
Hey guys I needed some of these for my gasser M275 truck.
Tm says
P/n 7539560
Figure number 8 in picture.
There larger then the m35A2 headlight bucket rubber Vibration dampers
.. thes are 3/8 inch
MuleMac01
158
Las Vegas Nevada
Got them thanks! there called General Purpose Vibration-Damping Sandwich Mounts with Studs
MuleMac01
158
Las Vegas Nevada
Check these out from John Deere M73249. We use them in the Early Deuce.
9376K48 and 9213K22 are also listed on the sassy G749 parts list at the top of this page https://www.steelsoldiers.com/forumdisplay.php?18-The-Early-Deuce
https://www.shopgreendealer.com/John-Deere-Isolator-M73249.html
Ty but it looks like 5/16 threads I just got my 3/8 ones in today. Going to put in a lathe tommrow and see if I can take a 1/2 inch off em. But I'm still looking. Because they might come apart.
gringeltaube
Staff Member
2,520
Montevideo/Uruguay
....... I just got my 3/8 ones in today. Going to put in a lathe tommrow and see if I can take a 1/2 inch off em. But I'm still looking. Because they might come apart.
Instead of using a cutting tool, try to do it with an angle grinder, with a 40-grain flapper disc.
MuleMac01
158
Las Vegas Nevada
Found them White owl surplus had them in stock the right kind also so I ordered 12. Thank you all who tried to help.
gringeltaube
Staff Member
2,520
Montevideo/Uruguay
OK, so you found what you wanted. But instead of deleting your ad I saved the info by moving this here to the Deuce forum - after a little "polishing"...
That way other members may have less trouble finding these parts.
Evil Dr. Porkchop
279
Colchester, VT
Even some of the a2 series have these old style headlight insulators. My 1966 m275a2 had them while my 1967 m35a2 had the newer style. I'll need to pick up a set of 12 insulators so if the ones you got from White Owl look good I'll probably give them a try. I haven't found an alternative yet although I haven't been looking too hard.
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
I just went through my notes. McMaster-Carr sold a 9376K45 which was the 3/8 and the K16 was the 5/16. Unfortunately they are not on their website anymore...
MuleMac01
158
Las Vegas Nevada
I'll post a picture of the new guys when they come.
