shawnshumvee
- 6
- 18
- Janesville WI
Hello. I should know this answer but I'm going to throw the question out there anyways.
In the mornings my Rig Makes a pretty good noise and then it goes away after about 30 secs. The noise sounds like a machine gun or a maybe a fast knock then it goes away and she is fine all day until the next morning. Now on a civilian gasoline engine this noise is contributed to a lack of lubrication. The way i understand it is, when an engine would set for a while all the oil would drain back down into the pan (thus no oil at the top of the engine at the moment). so when you hear the noise and then it quickly goes away its because the oil pump has done its job and delivered precious oil to the top of the engine. I believe this is the issue but not to sure? So was just wondering if this is a Diesel thing? I don't think it is a diesel thing because when its all said and done, the gasoline engine and a diesel engine are both 4 stroke internal combustion engines. Any info will help? Noises are not GOOD and if left uncorrected they will take there toll on my engine.
