acolesurf
- 0
- 6
- Vallejo, CA
Hey there everybody, I just recently purchased a M925A2, and have been having some fun with it, but now i've run into a problem...
While driving, my dog was sitting next to me, and when I hit the brakes, he started to slide off the seat, and braced himself by putting his paw on the dash. This is where the problem begins, he turned off the battery switch while the truck was still running. Next thing I saw were some blue sparks/electrical bursts coming from under the dash by the wires that only lasted about 1 second, and I immediately turned off the engine switch too. So then everything is shut off, I go to restart the truck, it starts up, but I am having some problems with some electronics now.
First, the air horn started sounding continuously, there is constant power to the air solenoid going to the horn under the hood, even when I unplug the power from the switch at the bottom of the steering column.
Next, the ABS light now stays on constantly. It used to go off once the truck was started, but now it stays on.
Other then that, I inspected all the wiring under the dash to try and see where the sparks came from, or if some wires melted together and are causing the short, but I can't seem to see anything. I checked both the fuses under the dash, the 15amp one was burned out, so I replaced it, but it did not change the symptoms. From looking through the TM, and the troubleshooting guide, I am wondering if the circuit breaker 10 is malfunctioning? but through the troubleshooting guide for the horn, it really only works through the issue of the horn not sounding at all, not the issue of the horn sounding all the time. As for the ABS, is there an ABS module that could be fried?
Thanks for all the help!!!
