- 6,425
- 4,987
- Ft. Lauderdale, Florida
There is no other place in this world to find the information needed
to refurbish a winch. Enjoy
Well if you have the TM 9-8617 like I do you will have that information.There is no other place in this world to find the information needed
ROTFL!!!Well if you have the TM 9-8617 like I do you will have that information.
I would post the information here if I could, but my internet speed is just a bit above "dial-up" !!!!!ROTFL!!!
Actually the TM9-8617 really goes into great detail on rebuilding. Most people won't need the information about "burnishing" your bushings but it's there if you do need it.I bet that most of that info is already available in our own library, to be found in TM9-1819AC (Part 5 of 6) Chapter 18, Sections I to VI.
Images and description are so much better than the more recent copies!
Gringeltaube,Short answer: NO...
That particular seal goes into the drum, not the housing. So you want to remove the drum - not the gear case.
Stand the whole winch upright, gear case facing down. Then undo 5 bolts and 1 nut; pull up the clutch side end housing and clutch-related parts; then the keys, then the drum. Everything else remains assembled.
