Drive shaft cup bolt troque specs ?
simp5782
Feo, Fuerte y Formal
9,369
Mason, TN
17-24 Ft*lb is literally engraved on the caps of my Neapco joints. 50 is an awful lot.
3/8" drive wrench at wrist strength tight is along the lines of 35ft lbs.
I have had better luck with Green Permatex threadlocker over the red. Especially with the vibrations these trucks have.
Awesomeness
1,518
Orlando, FL
The Neapco (4-0279) joints come with safety tab washers, that bend up against the head of the bolts, to prevent them from coming out. They work amazingly well, and you could still Loctite them if you wanted as well.
