pigpen60
- 127
- 43
- foley/missouri
My deuce is making oil. What should I do first?
Yea that is the overflow from the front side of the Head and the return fuel line to tank. The bypass only opens if there is a over pressure in the system.Okkkk, I eliminated the T on the input that had the line going under the cab. Guess I need to reinstall it?
The TM picture I posted was for me when figuring out what a stock system looks like so when I worked on it I would know which way the fuel is going from where to where and in which direction. The highlighted blue line is necessary. The engine must have a return to the tank and that is the blue highlighted line.So I need to replace the blue line back to the "t"? and reinstall the return to the tank?
Yes.So I need to replace the blue line back to the "t"? and reinstall the return to the tank?
