- 544
- 276
- 63
- Eubank, KY
I picked up the generator this morning from the commercial address I had it shipped to.
Installed the fuse mod.
Removed case over electrical end to check for any mouse invasion, there was none and the unit is very clean inside.
Checked the oil, CLEAN AND FULL.
Checked the coolant, clean and full.
Added 4gal clean fuel to tank.
Rotated the engine by hand several revolutions, have compression.
Installed batteries from my other set temporarily to test newer unit.
Switched dead crank switch and cranked the engine over a few times for about ten seconds each, it cranks well.
Turned on switch to prime and can see one relay in the line up of five behind the control panel pull in, fuel pump runs for a few seconds then stops. That relay drops out and the ones left and right of it pull in. The NO FUEL fault light comes on and the unit will not crank from the starter switch.
I inspected and swapped around and reseated all the relays and no joy.
I can hear a relay clicking under the cover as if it's trying to make contact and start but it's not cranking.
CB1 is engaged and not tripped.
I engaged the starter AT THE STARTER with a screwdriver and the engine cranks fine.
Its been raining here off and on for days so my time at the generator is cut short.
I'll be looking over the schematic this evening.
