24V solar charger
csheath
198
FL
I installed a new solar charging system on my 803 today. Purchased a 24V, 20W panel and charge controller off the auction sight. I have been using this same charge controller on another system to maintain the battery for my security cameras. I have two wifi cameras in the field I use to watch all the deer activity with. The charge controller auto senses whether you have it on a 12 or 24 volt system. Total cost $59.88 for both pieces.
My generator is up under my shed so it doesn't get a lot of sunlight. Sun probably peaks in a couple hours a day. I mounted the new panel on the end of the shed where it should get at least 6 hours of direct sunlight.
The panel measured 44 open circuit volts and 486 short circuit milliamps in direct sunlight. In the shade it was reading 36 volts and 70MA. Soon after connecting the volt reading went up on the batteries to 25.4 and the charge controller indicated it was float charging.
The nice thing about it is I mounted the charge controller right on top of the generator so I can monitor the battery condition every time I walk by. No more dead battery surprises.
ken
25
Houston Texas
I love your set up. My MEP 003 is inside the barn. So I removed my batteries and have them on a battery tender in my garage. I'd like to do this myself. It beats hauling batteries 300 feet to the barn.
csheath
198
FL
Today's battery reading with sun on the panel. Looks like the charge controller is regulating within parameters.
csheath
198
FL
My battery voltage is reading 25.2 this morning which is a tenth lower than they were before I put the new system on. I will need to monitor for a while to make sure it's doing what I need but I feel good about it. Right now it's cool and shady so I think all is normal.
One thing I haven't done is to run the unit under load. I will do that today and make sure there isn't a back feed problem with the charge controller. I asked this question of the seller and was told it would just go to float mode when it saw higher voltage on the battery side.
Where did you get the setup?
ebay
Search for
ALEKO 20W Monocrystalline Solar Panel 24 Volt Output
and
PWM 20/30A Solar Panel Charge Controller Regulator Battery Protection 12V/24V US
Check USA Only and set sort by lowest price. PM if you need the links.
csheath
198
FL
Ran the generator under load for a while today. Voltage indicator on charge controller read charging volts of 28 then returned to 26 after shut down. No apparent damage to the charge controller.
