Finally restoring the M37
GUNNY 155
elgin illinois
Looks like your almost there. Then once you start driving it after it is all together you get to deal with the teething troubles. Like tweaking the little things that no one will notice but just annoy the heck out of you as the owner. Looks great.
GUNNY 155
elgin illinois
M37Bruce. I know the feeling. I bought my M37 and got it into my shop. A few days later ended up in the hospital having a By Pass. It actually worked out because while I was recovering I sat on the computer and ordered parts. I had days where the UPS guy was stopping off twice a day.
hndrsonj
Senior Chief/Moderator
365
Cheyenne, WY
Last of the parts painted. Shifter, PTO linkage, and clutch hooked up. Headlights rebuilt and wired. Installed radiator, grill, and bridge plate.
hndrsonj
365
Cheyenne, WY
It is pretty much down to exhaust and install the wiring harness. I am taking the summer off before finishing it!:beer:
hndrsonj
365
Cheyenne, WY
Well back at it. The harness from Vintage is mostly in. Rear harness is totally done, the front harness is installed (hooked up), but is not clamped in. I still need engine/trans fluids, adjust/bleed brakes, install exhaust, air cleaner and a few really minor tweaks.
hndrsonj
365
Cheyenne, WY
Batteries and cables in. Installed a battery cutoff switch. Fording cables, speedometer, and wipers hooked up. Need to paint and install exhaust, bleed and adjust brakes, install air cleaner-then start it up!
