Dead Pilot's M36a2 Build
Dead pilot
135
Fallbrook, CA
Got some good work done on the deuce. Went through all 10 tires to put good one on. And got the drive shaft put back in and parking brake hooked back up.
Sent from my SM-N950U using Tapatalk
Dead pilot
135
Fallbrook, CA
Hopefully soon. Brakes are next to do this week or next and then once she starts then she'll move around the yard
Dead pilot
135
Fallbrook, CA
I wasn't planning on doing the wheels it just came up since we moved it. Or I would have done them then
Dead pilot
135
Fallbrook, CA
So I've came across a slight problem. I went to put the doors on and well the screw plates on the cab are shot. Either stripped out or broken screw in it. There's also a bit of rust on the driver side bottom of the door area and some up near the driver side windshield. It's seems next to impossible to get that plate out. Would it be better to changed out the cab or try and repair the spots.
rustystud
2,964
Woodinville, Washington
It's a bit tricky but the door plates can be changed out. You can make up your own out of stainless steel. The rust can also be dealt with, with a few well placed repair panels. Use the search function for people who have repaired their rusty cabs.
Dead pilot
135
Fallbrook, CA
I was able to get my hands a on cab that is in much better shape then the cab that's on the truck right now. And it's a good thing cause there was way more rust that was able to be seen till the fenders came off. And so many bolts are rusted in so bad. The new cab just needs a patch panel put in and it came with so that makes it easier
rustystud
2,964
I'm glad you where able to get another cab. Having to deal with major rust is a total pain !
Dead pilot
135
Fallbrook, CA
Got some work done on the the couple of days. The cut out peice has been replaced just need to get the mirror mounting peice for that side. Took all the hardware off the cab and clean the cab done for primer, undercoating, and then paint.
Next is tearing down the doors to make sure the windows work good and the latches are working.
So much to get done on this cab but since it's off I figured to do it right so it last and I don't have to do it again for a while
Dead pilot
135
Fallbrook, CA
More working done today. Got the old cab off and the rest of the good stuff out of it. And now it's in the scrap pile.
Next thing to come off is the bed.
Dead pilot
135
Fallbrook, CA
Having access to that crane made it so much easier to get that junk cab off. Even with leaving the steering column on.
Dead pilot
135
Fallbrook, CA
Yup still at it. Well getting back at it. I had shoulder surgery back in May and finally can start working on it again.
simp5782
Feo, Fuerte y Formal
9,368
Mason, TN
Whenever you get done with yours I've got an M36A2 and an M36A3 that need some attention too! if you feel motivated.
