lavarok
- 33
- 48
- Fellsmere, FL
Fellow PTO M1031 owners....today I was working on my gov system and with a little googling found the manufacturer tech manual for both the governor control and the actuator! Google "dyna 8000 install" and you will find the same manual I have attached here.
Also, an interesting tidbit: to verify your PTO MPU ( mag pickup ), use a multimeter to test resistance. Spec is 150 OHM.
I thought my mag pickup was toast, but it turns out the problem with my setup was a jumper wire some knuckle head installed from the overspeed control to the + actuator circuit. Very very odd as it worked 3 or 4 times, but after and since would run flat out whenever I engaged the gov circuit. Seems the wire jump may have fried the actual control of the overspeed as I can adjust the S1 potentiometer all day and it never kills the gov circuit.
Oh well, every other safety switch was previously removed and bypassed so what is wrong with ANOTHER failsafe being removed....kidding....
I am going to try swapping in an overspeed switch from my other M1031 and if that fails, I'll add a second switch to the gov circuit to prevent accidentally turning it on. Manual failsafe is better than no failsafe.
Without the jumper wire the system is now working flawlessly. The system ramps up within 10-12 secs per spec and sits at 60HZ without fail. I am looking for a manual or tech spec on the overspeed control as well as the ramp generator.
Those are the two items not covered by the attached manual. While neither are required for operation, they both provide valuable functions. The ramp generator slowly increases the voltage of the actuator circuit so it can slowly ramp up to the required RPM.
The overspeed control monitors RPM via the MPU and is supposed to kill power to the gov circuit when the RPMs exceed a value as dialed in via the S1 potentiometer. It is a failsafe to prevent engine failure due to excessive RPMs.
Enjoy!
Enjoy!
