Rusted on wheel, tire flat... now what?
319cssb
221
Easley SC
I got a flat rear tire. I would like to change it for a tire that holds air. Truck doesn't run ATM. So I can't drive it around the block with lug nuts loosened . Not that I could do that anyway, since the tire is flat. Sprayed it with a load of pb blaster, I pried, pulled and banged it with a BFH now the wheel is bent and still on like it's welded. What's next?
319cssb
221
Easley SC
I tried the bottle jack, but that didn't work too well with the jack being sideways. Then I tried a scissor jack. I cranked it a lot and still nothing happened. I will leave it like that for a while. I didn't feel like it coming off in a rather explosive way, with my hand under the wheel well. So far it didn't budge. I sprayed it with some PB blaster and went inside the house. I put some lug nuts on loosely just in case
Any other ideas?
cucvrus
10,434
Jonestown Pennsylvania
Rosebud torch it will pop right off. It is stuck on the center hub. A little heat and it will come right off. Report back. No torch try a propane torch. Not likely if you can't beat it off with a sledge hammer. Good Luck.
Ilikemtb999
45
Denver, CO
Maybe your bottle jack is low on oil.
Id keep cranking on it but it’ll probably pop pretty quickly so be ready. As others have said, it’s the center hub that’s stuck so you could heat it up in that area if you’ve got the means to do it.
Drock
12
Eatonton GA
Rust & frozen bolts are a lifestyle in Florida where I grew up. I had a wheel frozen on a front wheel drive Mitsubishi one time. That I could not get off, even after loosening the lugs and driving around the block. I ended up taking it to a tire shop, the tire tech took off the lugs, with his back to the wheel, he grabbed the top of the tire and pulled out with his body weight, while donkey kicking the bottom of the wheel, 3 kicks and it was off! Maybe you could do something similar with a come-along and a sludge hammer?
MarcusOReallyus
816
Virginia
Please post a photo of the nuts you are trying to remove. I have a hunch which might be wayyy off, but I'd like to see what you're up to, if you don't mind.
319cssb
221
Easley SC
Had the same problem with a rear wheel on my truck. A little help from a torch with MAPP gas popped it right off.
Took an awful lot of heat . Good thing I kept the lug nuts on the wheel. that thing popped with quite the force. thanks to the scissor jack under high tension
nyoffroad
690
Rochester NY
Never seize is your friend! Find some and buy it and USE it. I slather that stuff on the center and all the lug studs and never have a problem getting wheels off. I also use it on radiator and heater hoses too, love that stuff just have a rag handy when disassembling parts cause its messy.
