Csm Davis
- 393
- 83
- Hattiesburg, Mississippi
You are the one with a attitude and not able to read, those are listed as new and not being NOS as the old is a bad thing when dealing with rubber.Okay, put up.
Let's see you get a vacuum pump.
Because the part number in the picture on the left in your post does not match the picture.
It is not an emissions pump, it is a vacuum pump.
But actually I hope you have found 100 vacuum pumps.
That would be great.
Quit with the hubris and deliver the parts.
By the way, that is a new old stock pump that could be 30 years old.
The entire point of this is to find NEW parts.
It is no better than buying a used one.
But you are the expert...
Simp doesn't need one you do, so shut-up and order one yourself.
Sent from my SM-G930V using Tapatalk
