Stuttgarts996
- 2
- 0
- Danvers MA
Alright guys. Replaced my mechanical fuel pump after finding diesel in two hubs (truck ran fine though). This was last night. I let her idle for 5 min and drive a few 100 yds right after replacing . No issue. This am I started her up again and drove about an hr in stop and go traffic. After getting to work I shut her down came in for an hr then went out to move it. Upon start up she smoked white at ide but ran ok. Moved it to another spot and shut it down. Ten minutes later I restarted it and while running checked to see if any fuel would come out of the fuel filter petcock. As soon as I cracked it the truck died. Also no fuel came out. I then cracked the hard line at the mechanical fuel pump to see if it had fuel. Fuel seeped from the threads so looks like fuel is there. I did not do this while cranking though. I then removed the air screw from the filter housing and cranked 5-6 times for 10-15 second last each time but no fuel came from screw. I would assume that much cranking would have filled it? Any thoughts on where to go next. Hoping it’s something simple it’s my daily driver and I’m currently sitting at work . Needless to say until this gets sorted out I’m not going anywhere .
