Dock Rocker
- 72
- 28
- Jackson ms
Make sure the linkage is properly adjusted and that it’s not stuck between gears.Hello guys I have an 89 m998 and I only have forward and reverse in HL and L . When in H it feels like it engages but when I give it gas I get noise from the rear end differential. Fluid is check and clean. Any ideas on where to start checking components???? Thanks ALL
If not that then I bet you will be in the market for a torque converter and a transmission rebuild very soon.
I would check the linkage and if it’s properly adjusted throw It on a trailer and take it to a transmission shop.
