Heater Vent Control
Russm
69
Ft. Wainwright, AK
Took apart my dash and found a loose mechanical vent control push wire behind the heater control.
Does anyone have a picture of how this is supposed to look? I think I’m missing a part.
I’m finding only the electric connections in the TMs
In the second pic I am holding the
push wire
cucvrus
10,055
Jonestown Pennsylvania
Not seeing anything but the wires for the volt meter, the volt meter orange and black and a very dry heater control switch with bone dry cables. You need to remove the cables and switch and get all that stuff lubed and greased.
Russm
69
Ft. Wainwright, AK
the top cable is not connected to anything. Wondering where it goes
cucvrus
10,055
That BLUE piece on the end of the cable clips into the heater control switch. But before you do that the cables and switch need to be removed and lubed with oil and grease. No spray lube. May as well not bother using spray lubes. Unless you have a good cable and chain lube. But best results are remove clean well and then lube well. Good Luck. The cable can be straightened and reused again.
Green Puma
SLC, UT
Thank you!!
