devilphrog
- 5
- 6
- Melbourne, FL
Just wanted to pass along that I have found a solution to servicing the radiator on the MEP-803A (but should work find for the 802A's as well). I have a Lisle 24680 Spill Free Funnel that I used to fill up the radiator and bleed out the system. With the right included adapters, one can service and bleed the radiator and cooling system without making a mess and needing to tilt the unit over. It's around $20 and is handy for other radiator / coolant servicing on other vehicles as it includes many radiator cap adapters. It can be used with or without the top cover on the unit, and includes a plug that you can stick into the funnel once you're done to save the excess coolant that's bled out.
I'll see if I can attach a picture below.
Lisle 24680 Spill-Free FunnelLisle 24680 Spill-Free Funnel
